WP8548 & WP75xx Firmware Release 16 Components
  • Sep 28, 2018
  • Version: 16
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16 components and how to download it on your product.
WP8548 & WP75xx Firmware Release 16 combined image
SWI9X15Y_07.13.07.00 / 001.040_000
002.004
SWI9X15Y_07.13.05.00
18.06.1
18.06.1 Source
SWI9X15Y_07.13.05.00 Source
(Based on Kernel 3.14 and Yocto 2.2)
    • MCU Firmware: mcuFW.cwe
  • WP8548 & WP75xx Firmware Release 16
    This page describes the procedure to update WP8548 & WP75xx with the Firmware Release 16.
  • WPFirmwareRelease History item
    Available WP8548 & WP75xx Firmware Releases: WPx5xx Firmware Release 16.1/17 WPx5xx Firmware Release 16 WPx5xx Firmware Release 15 WPFirmwareRelease14 WPFirmwareRelease13.1 WPFirmwareRelease12.2 WPFirmwareRelease12 WPFirmwareRelease11 WPFirmwareRelease10 WPFirmwareRelease9
