WP8548 & WP75xx Firmware Release 16
- Sep 28, 2018
- Version: 16
This page describes the procedure to update WP8548 & WP75xx with the Firmware Release 16.
1. Download the USB driver and launch the executable 2. Download the Firmware .EXE file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R16 (Generic — GCF) 3. Connect the target's (e.g mangOH) USB cable to your host 4. Launch the executable and follow instructions |
Follow the Firmware Update Instructions with Developer Studio to download and install the following package: Legato for WP85/WP75 R16 (18.6.1.wp85-wp75-docker-201810021634) for Windows or Legato for WP85/WP75 R16 (18.6.1.wp85-wp75-native-x86_64-201810021635) for Linux |
1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R16 (Generic — GCF) 2. Connect the target's (e.g mangOH) USB cable to your host 3. Open a terminal and execute the Legato command line:
Consult the WP8548 & WP75xx Release 16 Customer Release Notes
| Carrier Approval |
| Generic — GCF |
SWI9X15Y_07.13.07.00 / 001.040_000 |
002.004 |
SWI9X15Y_07.13.05.00 |
18.06.1 |
If you build custom Linux Distribution or Base Legato System images for your product, see WP8548 & WP75xx Firmware Release 16 Components to create custom firmware packages.
WPFirmwareRelease History itemAvailable WP8548 & WP75xx Firmware Releases: WPx5xx Firmware Release 16.1/17 WPx5xx Firmware Release 16 WPx5xx Firmware Release 15 WPFirmwareRelease14 WPFirmwareRelease13.1 WPFirmwareRelease12.2 WPFirmwareRelease12 WPFirmwareRelease11 WPFirmwareRelease10 WPFirmwareRelease9
