WP76xx Firmware Release 8 Components
- Mar 1, 2018
- Version: 8
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 8 components and how to download it on your product.
WP76xx Firmware Release 8 combined image
SWI9X07Y_02.14.04.00 / 002.025_000 |
SWI9X07Y_02.10.01.00 / 002.015_001 |
| Modem Firmware (AT&T) |
| Modem Firmware (Verizon) |
SWI9X07Y_02.10.00.00 / 002.014_002 |
002.007 |
SWI9X07Y_02.14.04.00 |
18.01.0 |
| 18.01.0 Source |
SWI9X07Y_02.14.04.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
WP76xx Firmware Release 8This page describes the procedure to update WP76xx with Firmware Release 8.
