WP76xx Firmware Release 8
- Mar 1, 2018
- Version: 8
This page describes the procedure to update WP76xx with Firmware Release 8.
1. Download the USB driver and launch the executable. 2. Download the Firmware .EXE file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R8 (Generic — GCF) R8 (Generic — PTCRB) R8 (AT&T) R8 (Verizon) 3. Connect the target's (e.g mangOH) USB cable to your host 4. Launch the executable and follow instructions |
1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R8 (Generic — GCF) R8 (Generic — PTCRB) R8 (AT&T) R8 (Verizon) 2. Connect the target's (e.g mangOH) USB cable to your host 3. Open a terminal and execute the Legato command line:
1. On AirVantage, monitor the system to be updated. 2. Select More > Install Bundle. 3. Select the desired firmware bundle: WP7601 (Generic) Release 8 WP7601 (Verizon) Release 8 WP7601-1 (Generic) Release 8 WP7601-1 (Verizon) Release 8 WP7603 (ATT) Release 8 WP7603 (PTCRB) Release 8 WP7603-1 (ATT) Release 8 WP7603-1 (PTCRB) Release 8 4. Start the install procedure. The operation will now be "In progress" state and visible in the System Operations widget. |
Consult the WP76xx Release 8 Customer Release Notes
| Carrier Approval |
| Generic — GCF |
SWI9X07Y_02.14.04.00 / 002.025_000 |
002.007 |
SWI9X07Y_02.14.04.00 |
18.01.0 |
| Generic — PTCRB | SWI9X07Y_02.10.01.00 / 002.015_001 | 002.007 | SWI9X07Y_02.14.04.00 | 18.01.0 |
| AT&T | SWI9X07Y_02.10.01.00 / 002.015_001 | 002.007 | SWI9X07Y_02.14.04.00 | 18.01.0 |
| Verizon | SWI9X07Y_02.10.00.00 / 002.014_002 | 002.007 | SWI9X07Y_02.14.04.00 | 18.01.0 |
If you build custom Linux Distribution or Base Legato System images for your product, see WP76xx Firmware Release 8 Components to create custom firmware packages.
