WP76xx Firmware Release 8.0.0.1 Components
- Dec 1, 2021
- Version: 8.0.0.1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 8.0.0.1 components and how to download it on your product.
WP76xx Firmware Release 8.0.0.1 combined image
| Modem Firmware (Generic) |
SWI9X07Y_02.14.04.00 / 002.025_001 |
002.007 |
SWI9X07Y_02.14.05.01 |
18.01.0 |
| 18.01.0 Source |
SWI9X07Y_02.14.05.01 Source (Based on Kernel 3.18 and Yocto 2.2) |
WP76xx Firmware Release 8.0.0.1This page describes the procedure to update WP76xx with Firmware Release 8.0.0.1
