WP76xx Firmware Release 8.0.0.1
  • Dec 1, 2021
  • Version: 8.0.0.1
This page describes the procedure to update WP76xx with Firmware Release 8.0.0.1
     R8.0.0.1 (Generic)
    Legato for WP76 R8 (18.1.0.wp76xx-docker-201803051401) for Windows
    or
    Legato for WP76 R8 (18.1.0.wp76xx-native-x86_64-201803051402) for Linux
      R8.0.0.1 (Generic)
Consult the WP76xx Release 8.0.0.1 Customer Release Notes
Generic — GCF
SWI9X07Y_02.14.04.00 / 002.025_001
002.007
SWI9X07Y_02.14.05.01
18.01.0
If you build custom Linux Distribution or Base Legato System images for your product, see WP76xx Firmware Release 8.0.0.1 Components to create custom firmware packages.
  • WP76xx Firmware Release 8.0.0.1 Components
    This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 8.0.0.1 components and how to download it on your product.
