WP76xx Firmware Release 10.1 Components
- Oct 22, 2018
- Version: 10.1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 10.1 components and how to download it on your product.
WP76xx Firmware Release 10.1 combined image
| Modem Firmware (Generic — GCF/PTCRB) |
SWI9X07Y_02.18.05.00 / 002.041_002 |
| Modem Firmware (AT&T) |
SWI9X07Y_02.18.05.00 / 002.040_001 |
| Modem Firmware (Sierra Wireless) |
SWI9X07Y_02.18.05.00 / 001.002_000 |
002.009 |
SWI9X07Y_02.18.06.00 |
18.06.3 |
| 18.06.3 Source |
SWI9X07Y_02.18.06.00 Source (Based on Kernel 3.18.44 and Yocto 2.2.2) |
WP76xx Firmware Release 10.1This page describes the procedure to update WP76xx with Firmware Release 10.1.
