WP76xx Firmware Release 10.1
  • Nov 8, 2018
  • Version: 10.1
This page describes the procedure to update WP76xx with Firmware Release 10.1.
         R10.1 (Generic — GCF/PTCRB) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610
         R10.1 (AT&T) — WP7603
         R10.1 (Sierra Wireless) — WP7601, WP7603, WP7607, WP7610
    Legato for WP76 R10.1 (18.6.3.wp76xx-docker-201810311826) for Windows
    or
    Legato for WP76 R10.1 (18.6.3.wp76xx-native-x86_64-201810311828) for Linux
Consult the WP76xx Release 10.1 Customer Release Notes
Generic — GCF/PTCRB
SWI9X07Y_02.18.05.00 / 002.041_002
002.009
SWI9X07Y_02.18.06.00
18.06.3
AT&T SWI9X07Y_02.18.05.00 / 002.040_001 002.009 SWI9X07Y_02.18.06.00 18.06.3
Sierra Wireless SWI9X07Y_02.18.05.00 / 001.002_000 002.009 SWI9X07Y_02.18.06.00 18.06.3
If you build custom Linux Distribution or Base Legato System images for your product, see WP76xx Firmware Release 10.1 Components to create custom firmware packages.
