WP76xx Firmware Release 10.1.1 Components
  • Nov 9, 2018
  • Version: 10.1.1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 10.1.1 components and how to download it on your product.
WP76xx Firmware Release 10.1.1 combined image
Modem Firmware (Generic — GCF/PTCRB)
SWI9X07Y_02.18.05.00 / 002.041_002
Modem Firmware (AT&T)
SWI9X07Y_02.18.05.00 / 002.040_001
Modem Firmware (Verizon)
SWI9X07Y_02.18.05.00 / 002.041_001
SWI9X07Y_02.18.05.00 / 001.002_000
002.009
SWI9X07Y_02.18.06.00
18.06.3
18.06.3 Source
SWI9X07Y_02.18.06.00 Source
(Based on Kernel 3.18.44 and Yocto 2.2.2)
  • WP76xx Firmware Release 10.1
    This page describes the procedure to update WP76xx with Firmware Release 10.1.
