WP76xx Firmware Release 10.1.1.1 Components
  • May 23, 2022
  • Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 10.1.1.1 components and how to download it on your product.
WP76xx Firmware Release 10.1.1.1 combined image
Modem Firmware (Generic)
SWI9X07Y_02.18.05.00 / 002.041_004
Modem Firmware (AT&T)
SWI9X07Y_02.18.05.00 / 002.040_003
Modem Firmware (Verizon)
SWI9X07Y_02.18.05.00 / 002.041_003
SWI9X07Y_02.18.05.00 / 001.002_003
002.009
SWI9X07Y_02.18.07.02
18.06.3
18.06.3 Source
SWI9X07Y_02.18.07.02 Source
(Based on Kernel 3.18.44 and Yocto 2.2.2)
Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example"  and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory.
  • WP76xx Firmware Release 10.1.1.1
    This page describes the procedure to update WP76xx with Firmware Release 10.1.1.1
  • WP76xx Release 10.1.1.1 Customer Release Notes
    This is the WP76xx Release 10.1.1.1 Customer Release Notes download.
