WP76xx Firmware Release 10.1.1.1
  • Sep 7, 2022
  • Version: 3.0
This page describes the procedure to update WP76xx with Firmware Release 10.1.1.1
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 10.1.1.1 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP76xx Firmware Release 10.1.1.1 Components to create custom firmware packages.
         R10.1.1.1 (Generic) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610
         R10.1.1.1 (AT&T) — WP7603
         R10.1.1.1 (Verizon) — WP7601
         R10.1.1.1 (Sierra Wireless) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610
    Legato for WP76 R10.1 (18.6.3.wp76xx-docker-201810311826) for Windows
    or
    Legato for WP76 R10.1 (18.6.3.wp76xx-native-x86_64-201810311828) for Linux
For details about this firmware release, refer to the WP76xx Release 10.1.1.1 Customer Release Notes.
Generic
SWI9X07Y_02.18.05.00 / 002.041_004
002.009
SWI9X07Y_02.18.07.01
18.06.3
AT&T SWI9X07Y_02.18.05.00 / 002.040_003 002.009 SWI9X07Y_02.18.07.01 18.06.3
Verizon SWI9X07Y_02.18.05.00 / 002.041_003 002.009 SWI9X07Y_02.18.07.01 18.06.3
Sierra Wireless SWI9X07Y_02.18.05.00 / 001.002_003 002.009 SWI9X07Y_02.18.07.01 18.06.3
  • WP76xx Firmware Release 10.1.1.1 Components
    This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 10.1.1.1 components and how to download it on your product.
  • WP76xx Release 10.1.1.1 Customer Release Notes
    This is the WP76xx Release 10.1.1.1 Customer Release Notes download.
