WP76xx Firmware Release 10.1.0.1 Components
- May 23, 2022
- Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 10.1.0.1 components and how to download it on your product.
WP76xx Firmware Release 10.1.0.1 combined image
| Modem Firmware (Generic) |
SWI9X07Y_02.18.05.00 / 002.041_004 |
| Modem Firmware (AT&T) |
SWI9X07Y_02.18.05.00 / 002.040_003 |
| Modem Firmware (Sierra Wireless) |
SWI9X07Y_02.18.05.00 / 001.002_003 |
| Verizon | SWI9X07Y_02.10.00.00 / 002.014_003 SWI9X07Y_02.18.05.00 / 002.041_003 |
Custom Modem Firmware can NOT be created by customers | |
002.009 |
SWI9X07Y_02.18.07.02 |
18.06.3 |
| 18.06.3 Source |
SWI9X07Y_02.18.07.02 Source (Based on Kernel 3.18.44 and Yocto 2.2.2) |
Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example" and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory.
WP76xx Firmware Release 10.1.0.1This page describes the procedure to update WP76xx with Firmware Release 10.1.0.1
WP76xx Release 10.1.0.1 Customer Release NotesThis is the WP76xx Release 10.1.0.1 Customer Release Notes download.
