WP76xx Firmware Release 10.1.0.1
- May 28, 2022
- Version: 2.0
This page describes the procedure to update WP76xx with Firmware Release 10.1.0.1
WP76xx firmware is available:
- As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 10.1.0.1 Updates, below.
- As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP76xx Firmware Release 10.1.0.1 Components to create custom firmware packages.
1. Download the USB driver and launch the executable. 2. Download the Firmware .EXE file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R10.1.0.1 (Generic) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610 R10.1.0.1 (AT&T) — WP7603 R10.1.0.1 (Sierra Wireless) — WP7601, WP7603, WP7607, WP7610 R10.1.0.1 (Verizon) 3. Connect the target's (e.g mangOH) USB cable to your host 4. Launch the executable and follow instructions |
Consult the WP76xx Release 10.1.0.1 Customer Release Notes
| Carrier Approval |
| Generic |
SWI9X07Y_02.18.05.00 / 002.041_004 |
002.009 |
SWI9X07Y_02.18.07.02 |
18.06.3 |
| AT&T | SWI9X07Y_02.18.05.00 / 002.040_003 | 002.009 | SWI9X07Y_02.18.07.02 | 18.06.3 |
| Sierra Wireless | SWI9X07Y_02.18.05.00 / 001.002_003 | 002.009 | SWI9X07Y_02.18.07.02 | 18.06.3 |
| Verizon | SWI9X07Y_02.10.00.00 / 002.014_003 SWI9X07Y_02.18.05.00 / 002.041_003 |
WP76xx Firmware Release 10.1.0.1 ComponentsThis page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 10.1.0.1 components and how to download it on your product.
WP76xx Release 10.1.0.1 Customer Release NotesThis is the WP76xx Release 10.1.0.1 Customer Release Notes download.
