WP76xx Firmware Release 9 Components
- May 2, 2018
- Version: 9
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 9 components and how to download it on your product.
WP76xx Firmware Release 9 combined image
SWI9X07Y_02.16.02.00 / 002.032_000 |
SWI9X07Y_02.10.01.00 / 002.015_001 |
| Modem Firmware (AT&T) |
| Modem Firmware (Verizon) |
SWI9X07Y_02.10.00.00 / 002.014_002 |
002.009 |
SWI9X07Y_02.16.02.00 |
18.03.0 |
| 18.03.0 Source |
SWI9X07Y_02.16.02.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
- WP76xx Firmware Release 8
This page describes the procedure to update WP76xx with Firmware Release 8.
