WP8548 & WP75xx Firmware Release 15 Components
- Jan 11, 2018
- Version: 15
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 15 components and how to download it on your product.
WP8548 & WP75xx Firmware Release 15 combined image
SWI9X15Y_07.12.14.00 / 001.034_000 |
SWI9X15Y_07.12.09.00 / 001.033_000 |
| Modem Firmware (AT&T) |
SWI9X15Y_07.12.09.00 / 001.028_000 |
| Modem Firmware (Sprint) |
SWI9X15Y_07.12.09.00 / 001.020_000 |
002.004 |
SWI9X15Y_07.12.14.00 |
16.10.4 |
| 16.10.4 Source |
SWI9X15Y_07.12.14.00 Source (Based on Kernel 3.18 and Yocto 1.7) |
WP8548 & WP75xx Firmware Release 15This page describes the procedure to update WP8548 & WP75xx with the Firmware Release 15.
WPFirmwareRelease History itemAvailable WP8548 & WP75xx Firmware Releases: WPx5xx Firmware Release 16.1/17 WPx5xx Firmware Release 16 WPx5xx Firmware Release 15 WPFirmwareRelease14 WPFirmwareRelease13.1 WPFirmwareRelease12.2 WPFirmwareRelease12 WPFirmwareRelease11 WPFirmwareRelease10 WPFirmwareRelease9
