WP77xx Firmware Release 9 Components
- Jun 5, 2018
- Version: 9
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 9 components and how to download it on your product.
WP77xx Firmware Release 9 combined image
| Modem Firmware (Generic — Not certified; test purposes only) |
SWI9X06Y_02.16.04.00 / 001.021_000 |
| Modem Firmware (AT&T — Not certified; test purposes only) |
SWI9X06Y_02.16.04.00 / 001.019_000 |
002.009 |
SWI9X06Y_02.16.02.00 |
18.03.0 |
| 18.03.0 Source |
SWI9X06Y_02.16.02.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
