WP77xx Firmware Release 9.1 Components
- Aug 18, 2018
- Version: 9.1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 9.1 components and how to download it on your product.
WP77xx Firmware Release 9.1 combined image
| Modem Firmware (Generic — GCF/PTCRB) |
SWI9X06Y_02.16.06.00 / 001.028_001 |
| Modem Firmware (AT&T |
SWI9X06Y_02.16.06.00 / 001.026_000 |
002.009 |
SWI9X06Y_02.18.05.00 |
18.06.1 |
| 18.06.1 Source |
SWI9X06Y_02.18.05.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
