WP77xx Firmware Release 8 Components
- Mar 5, 2018
- Version: 8
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 8 components and how to download it on your product.
WP77xx Firmware Release 8 combined image
| Modem Firmware (Generic — Not certified; test purposes only) |
SWI9X06Y_02.14.04.00 / 001.012_000 |
| Modem Firmware (AT&T — Not certified; test purposes only) |
SWI9X06Y_02.14.04.00 / 001.011_000 |
002.007 |
SWI9X06Y_02.14.04.00 |
18.01.0 |
| 18.01.0 Source |
SWI9X06Y_02.14.04.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
WP77xx Firmware Release 7This page describes the procedure to update WP77xx with the Firmware Release 7.
