WP77xx Firmware Release 11 Components
- Oct 1, 2019
- Version: 11
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 11 components and how to download it on your product.
WP77xx Firmware Release 11 combined image
SWI9X06Y_02.22.12.00 / 001.051_000 |
SWI9X06Y_02.16.06.00 / 001.028_004 |
| Modem Firmware (AT&T) |
SWI9X06Y_02.16.06.00 / 001.026_001 |
| Modem Firmware (Deutsche Telekom) |
| Modem Firmware (Sierra Wireless — GCF) |
SWI9X06Y_02.22.12.00 / 001.021_000 |
| Modem Firmware (Verizon) |
SWI9X06Y_02.22.12.00 / 001.042_000 |
002.011 |
SWI9X06Y_02.22.12.00 |
18.09.2 |
| 18.09.2 Source |
SWI9X06Y_02.22.12.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
