WP76xx Firmware Release 6 Components
- Oct 24, 2017
- Version: 6
This page describes in details the components included with the Firmware Release, how to build your own custom device image based on Release 6 components and how to download it on your product.
WP76xx Firmware Release 6 combined image
| Modem Firmware (Generic) |
SWI9X07Y_02.09.02.00 / 002.009_000 |
002.004 |
SWI9X07Y_02.09.02.00 |
17.08.1 |
| 17.08.1 Source |
SWI9X07Y_02.09.02.00 Source (Based on Kernel 3.18 and Yocto 1.7) |
Note 1: you may decide to generate a custom Device Image without the full list of components (e.g. without Modem Firmware or without the Linux Distribution). If you do so, when you will flash this image later, only the components included within the custom Device Image package will be updated, the others will remain untouched. By doing this, you shall insure that the untouched components are compliant with the ones you are updating through the custom Device Image.
- WP76xx Firmware Release 6
This page describes the procedure to update WP76xx with the Firmware Release 6
