WP76xx Firmware Release 7 Components
- Jan 13, 2018
- Version: 7
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 7 components and how to download it on your product.
WP76xx Firmware Release 7 combined image
SWI9X07Y_02.13.02.00 / 002.018_000 |
SWI9X07Y_02.10.01.00 / 002.015_000 |
| Modem Firmware (AT&T) |
| Modem Firmware (Verizon) |
SWI9X07Y_02.10.00.00 / 002.014_002 |
002.006 |
SWI9X07Y_02.13.02.00 |
17.11.0 |
| 17.11.0 Source |
SWI9X07Y_02.13.02.00 Source (Based on Kernel 3.18 and Yocto 2.2) |
- WP76xx Firmware Release 7.0.1
This page describes the procedure to update WP76xx with Firmware Release 7.0.1.
