WP76xx Firmware Release 4.1 Components
  • Jul 13, 2017
  • Version: 4.1
This page describes in details the components included with the Firmware Release, how to build your own custom device image based on Release 4.1 components and how to download it on your product.
WP76xx Firmware Release 4.1 combined image
Modem Firmware (Generic)
SWI9X07Y_02.04.04.00 / 001.001_000
002.001
Not Available for this release
17.05.0.RC5
Legato Source Linux Distro Source  Linux Distro Release Note  Linux Distro Licenses  Toolchain
17.05.0.RC5 Source
SWI9X07Y_02.04.04.00 Source
(Based on Kernel 3.18 and Yocto 1.7)
Not available for this release
    • MCU Firmware: mcuFW.cwe
you may decide to generate a custom Device Image without the full list of components (e.g. without Modem Firmware or without the Linux Distribution). If you do so, when you will flash this image later, only the components included within the custom Device Image package will be updated, the others will remain untouched. By doing this, you shall insure that the untouched components are compliant with the ones you are updating through the custom Device Image.
fwupdate download <combined_image_file> 192.168.225.1
  • WP76xx Firmware Release 4.1
    This page describes the procedure to update WP76xx with the Firmware Release 4.1.
    Available WP76xx Firmware Releases: WP76xx Firmware Release 17.1 WP76xx Firmware Release 17 WP76xx Firmware Release 16.3 WP76xx Firmware Release 16.1 WP76xx Firmware Release 16.0.1 WP76xx Firmware Release 13.1.1/13.2.1/13.3.1 WP76xx Firmware Release 13.0.1 WP76xx Firmware Release 12.0.1 WP76xx Firmware Release 10.1.1.1 WP76xx Firmware Release 10.1.0.1 &nbsp;&nbsp; Note: If you require access to older releases, contact your Semtech representative.
WP76xx Firmware Release 4.1 Components | Source
