WP76xx Firmware Release 13 Components
- May 31, 2019
- Version: 13
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13 components and how to download it on your product.
The WP76xx device's flash is partitioned according to the following diagram. Some partitions are customizable and can be updated by either using the default image provided by Sierra Wireless or by customizing the image and updating the partition using your own customized image. Images can either be updated by connecting to the device directly or remotely updating the device over the air (SOTA and FOTA), by using AirVantage.
To find the current version of your firmware run "fwupdate query" on your target.
Non-customizable components are provided as .cwe image files and are included within the Leaf SDK or are individually downloadable. Follow the instructions below to combine the .cwe files into an .spk and update the firmware partition of your device.
Binary Components:
| Component | Leaf SDK Image Location | Binary .cwe file |
Source Code |
/leaf-data/<profilename>/wp76-modem-image or use environment variable $WP76XX_MODEM_IMAGES |
SWI9X07Y_02.28.03.01 / 002.064_000 |
Not available |
| Modem Firmware (AT&T) |
SWI9X07Y_02.28.03.01 / 002.071_000 |
Not available |
002.011 |
MCU Firmware is included as part of Linux Distribution. Custom MCU Firmware can NOT be created by customers. |
/leaf-data/<profilename>/wp76-linux-image or use environment variable $WP76XX_LINUX_IMAGE |
SWI9X07Y_02.28.03.01 |
Leaf: leaf getsrc swi-linux Gerrit: repo init -u ssh://<userid>@gerrit.legato.io:29418/manifest -m products/wp76xx/releases/Release13.xml -g default,-cache; repo sync (Clones both Legato and Linux Source Code) Tarball: SWI9X07Y_02.28.03.01 Source (Based on Kernel 3.18.122 and Yocto 2.2.2) |
/leaf-data/<profilename>/wp76-legato-image or use environment variable $WP76XX_LEGATO_IMAGE |
19.02.0 |
Leaf: leaf getsrc legato Gerrit: repo init -u ssh://<userid>@gerrit.legato.io:29418/manifest -m products/wp76xx/releases/Release13.xml -g default,-cache; repo sync (Clones both Legato and Linux Source Code) Tarball: 19.02.0 Source |
- either to add/remove a driver within your Linux kernel
- or/and to add/remove FOSS (Free Open Source Software) from your Root FileSystem
- either to add your apps as part of the native apps deployed within the Base Legato System (recommended to create production units):
- or/and to rebuild the Legato Application Framework from the open source project. To do so, go to"Rebuild Linux Distribution or/and Legato from source"
Custom Legato systems and applications can be built by customers. To do so you need a copy of the Legato Application Framework and the toolchain installed on a Linux development machine (virtual or physical). The Legato Application Framework and all tools (including the toolchain) are automatically downloaded, installed and configured with the Leaf Workspace Manager. Sierra Wireless also provides the source code on our Gerrit Server, and can be cloned by using the repo tool.
| Open Source Licenses | 32-bit ToolChain 64-bit ToolChain |
| Repo Command (replace <userid> with your Gerrit User ID), clones both the Legato Source Code and Linux Source Code: repo init -u ssh://<userid>@gerrit.legato.io:29418/manifest -m products/wp76xx/releases/Release13.xml -g default,-cache; repo sync |
WP76xx Firmware Release 13 combined image
WP76xx Firmware Release 13This page describes the procedure to update WP76xx with Firmware Release 13.
