WP76xx Firmware Release 13 Components
- Jun 12, 2019
- Version: 13
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13 components and how to download it on your product.
WP76xx Firmware Release 13 combined image
SWI9X07Y_02.28.03.01 / 002.064_000 |
| Modem Firmware (AT&T) |
SWI9X07Y_02.28.03.01 / 002.071_000 |
002.011 |
SWI9X07Y_02.28.03.01 |
19.02.0 |
| 19.02.0 Source |
SWI9X07Y_02.28.03.01 Source (Based on Kernel 3.18.122 and Yocto 2.5) |
WP76xx Firmware Release 13This page describes the procedure to update WP76xx with Firmware Release 13.
