WP76xx Firmware Release 13.1.1/13.2.1/13.3.1 Components
- May 23, 2022
- Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13.1.1, 13.2.1 and 13.3.1 components and how to download it on your product.
Release 13.1/13.2/13.3 Components
WP76xx Firmware Release 13.1/13.2/13.3 combined image
(R13.1.1) SWI9X07Y_02.28.03.03 / 002.068_003 |
| (R13.2.1) SWI9X07Y_02.28.03.03 / 002.068_002 | Download | ||
| (R13.3.1) SWI9X07Y_02.28.03.05 / 002.073_001 | Download | ||
(R13.1.1) SWI9X07Y_02.28.03.01 / 002.064_003 |
| (R13.2.1) SWI9X07Y_02.28.03.01 / 002.064_002 | Download | ||
| Modem Firmware (AT&T) |
(R13.2.1) SWI9X07Y_02.28.03.01 / 002.071_006 |
| Modem Firmware (DOCOMO) |
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.024_001 | Download |
| Modem Firmware (KDDI) |
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.026_002 | Download |
| Modem Firmware (Softbank) |
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.028_001 | Download |
| Modem Firmware (Telstra) |
(R13.3.1) SWI9X07Y_02.28.03.05 / 001.058_001 | Download |
| Modem Firmware (Telus) |
(R13.2.1) SWI9X07Y_02.28.03.01 / 001.000_002 | Download |
| Modem Firmware (Verizon) |
(R13.2.1) SWI9X07Y_02.28.03.04 / 002.075_002 |
| Modem Firmware (Sierra Wireless— GCF) |
(R13.1.1) SWI9X07Y_02.28.03.03 / 001.026_003 |
| (R13.2.1) SWI9X07Y_02.28.03.03 / 001.026_002 | Download | ||
| (R13.3.1) SWI9X07Y_02.28.03.05 / 001.032_001 | Download | ||
002.011 |
(R13.1.1) SWI9X07Y_02.28.06.02 |
| (R13.2.1) SWI9X07Y_02.28.05.03 |
| (R13.3.1) SWI9X07Y_02.28.04.02 |
19.02.0 |
| Legato Source | Release # |
Linux Distro Source | Linux Distro Licences |
| 19.02.0 Source |
R13.1.1 | (Based on Kernel 3.18.131 and Yocto 2.5) SWI9X07Y_02.28.06.02 Source |
| R13.2.1 | (Based on Kernel 3.18.131 and Yocto 2.5) SWI9X07Y_02.28.05.03 Source |
| R13.3.1 | (Based on Kernel 3.18.131 and Yocto 2.5) SWI9X07Y_02.28.04.02 Source |
Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example" and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory.
WP76xx Firmware Release 13.1.1/13.2.1/13.3.1This page describes the procedure to update WP76xx with Firmware Release 13.1.1, 13.2.1 or 13.3.1.
WP76xx Release 13.1.1/13.2.1/13.3.1 Customer Release NotesThis is the WP76xx Release 13.1.1/13.2.1/13.3.1 Customer Release Notes download.
