WP76xx Firmware Release 12 Components
- Feb 28, 2019
- Version: 12
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 12 components and how to download it on your product.
WP76xx Firmware Release 12 combined image
SWI9X07Y_02.25.02.01 / 002.056_000 |
SWI9X07Y_02.18.05.00 / 002.041_003 |
| Modem Firmware (AT&T) |
SWI9X07Y_02.18.05.00 / 002.040_002 |
| Modem Firmware (Verizon) |
SWI9X07Y_02.18.05.00 / 002.041_002 |
| Modem Firmware (Sierra Wireless (GCF)) |
SWI9X07Y_02.25.02.01 / 001.014_000 |
| Modem Firmware (Sierra Wireless (PTCRB)) |
SWI9X07Y_02.18.05.00 / 001.002_001 |
002.011 |
SWI9X07Y_02.25.02.01 |
18.10.3 |
| 18.10.3 Source |
SWI9X07Y_02.25.02.01 Source (Based on Kernel 3.18.122 and Yocto 2.2.2) |
WP76xx Firmware Release 12This page describes the procedure to update WP76xx with Firmware Release 12.
