WP76xx Firmware Release 12.0.1 Components
- May 23, 2022
- Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 12.0.1 components and how to download it on your product.
WP76xx Firmware Release 12.0.1 combined image
SWI9X07Y_02.18.05.00 / 002.041_005 |
| Modem Firmware (Generic — GCF) | SWI9X07Y_02.25.02.01 / 002.056_002 | Download | Custom Modem Firmware can NOT be created by customers |
| Modem Firmware (AT&T) |
SWI9X07Y_02.18.05.00 / 002.040_003 |
| Modem Firmware (Verizon) |
SWI9X07Y_02.18.05.00 / 002.041_003 |
| Modem Firmware (Sierra Wireless (PTCRB)) | SWI9X07Y_02.18.05.00 / 001.002_004 | Download | Custom Modem Firmware can NOT be created by customers |
| Modem Firmware (Sierra Wireless (GCF)) |
SWI9X07Y_02.25.02.01 / 001.014_002 |
002.011 |
SWI9X07Y_02.25.04.01 |
18.10.3 |
| 18.10.3 Source |
SWI9X07Y_02.25.04.01 Source (Based on Kernel 3.18.122 and Yocto 2.2.2) |
Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example" and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory.
WP76xx Firmware Release 12.0.1This page describes the procedure to update WP76xx with Firmware Release 12.0.1
WP76xx Release 12.0.1 Customer Release NotesThis is the WP76xx Release 12.0.1 Customer Release Notes download.
