WP76xx Firmware Release 16.0.1 Components
- May 23, 2022
- Version: 2.0
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16.0.1 components and how to download it on your product.
WP76xx Firmware Release 16.0.1 combined image
| Modem Firmware (Generic — GCF & PTCRB) |
SWI9X07Y_02.37.03.00 / 002.095_003 |
| Modem Firmware (AT&T — PTCRB) |
SWI9X07Y_02.37.00.00 / 002.098_003 |
| Modem Firmware (Sierra Wireless — GCF) |
SWI9X07Y_02.37.03.00 / 001.060_003 |
| Modem Firmware (Sprint — GCF) |
SWI9X07Y_02.37.02.00 / 001.027_003 | Download |
| Modem Firmware (T-Mobile — PTCRB) |
SWI9X07Y_02.35.02.00 / 001.017_001 | Download |
| Modem Firmware (Verizon — GCF) |
SWI9X07Y_02.37.06.00 / 002.107_003 |
002.015 |
SWI9X07Y_02.37.10.02 |
19.11.2 |
| Legato Source | Release # |
Linux Distro Source | Linux Distro Licences |
| 19.11.2 Source |
R16.0.1 | (Based on Kernel 3.18.140 and Yocto 2.5) SWI9X07Y_02.37.10.02 Source Note: The Linux Distro Source, ONLY purposed for rebuilding the Linux Distribution, has been updated with "SWI9x07Y_02.37.10.01 - for example" and correctly configured in order to accommodate changes made through new memory driver updates. No impact on all the shipping SKU's directly from factory. |
WP76xx Firmware Release 16.0.1This page describes the procedure to update WP76xx with Firmware Release 16.0.1
