WP76xx Firmware Release 16.0.1
  • May 8, 2023
  • Version: 3.0
This page describes the procedure to update WP76xx with Firmware Release 16.0.1
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 16.0.1 Updates, below.
    See WP76xx Firmware Release 16.0.1 Components to create custom firmware packages.
'One-click' tool
         R16.0.1 (Generic — GCF & PTCRB) — WP7601, WP7603, WP7607, WP7610, WP7611
         R16.0.1 (AT&T — PTCRB) — WP7603, WP7610, WP7611
         R16.0.1 (Sierra Wireless — GCF) — WP7603, WP7607, WP7610, WP7611
         R16.0.1 (Sprint — GCF) — WP7611
         R16.0.1 (T-Mobile — PTCRB) — WP7611
         R16.0.1 (Verizon — GCF) — WP7601, WP7610, WP7611
MBPL (Linux)   1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.):
Leaf Workspace Manager
For details about this firmware release, refer to the WP76xx Release 16.0.1 Customer Release Notes.
SWI9X07Y_02.37.03.00 / 002.095_003 002.015
SWI9X07Y_02.37.10.02 19.11.2
AT&T — PTCRB SWI9X07Y_02.37.00.00 / 002.098_003 002.015 SWI9X07Y_02.37.10.02 19.11.2
SWI9X07Y_02.37.03.00 / 001.060_003 002.015 SWI9X07Y_02.37.10.02 19.11.2
Sprint — GCF SWI9X07Y_02.37.02.00 / 001.027_003 002.015 SWI9X07Y_02.37.10.02
19.11.2
T-Mobile — PTCRB SWI9X07Y_02.35.02.00 / 001.017_001 002.015 SWI9X07Y_02.37.10.02 19.11.2
Verizon — GCF SWI9X07Y_02.37.06.00 / 002.107_003 002.015 SWI9X07Y_02.37.10.02 19.11.2
  • WP76xx Firmware Release 16.0.1 Components
