WP77xx Firmware Release 13
  • Aug 6, 2020
  • Version: 13
This page describes the procedure to update WP77xx with Firmware Release 13.
WP77xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 13 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP77xx Firmware Release 13 Components to create custom firmware packages.
         R13 (Generic — GCF)
         R13 (Generic — PTCRB)
         R13 (AT&T)
         R13 (Deutsche Telekom)
         R13 (Sierra Wireless — GCF)
         R13 (T-Mobile US)
         R13 (Verizon)
(Linux) Legato CLI
         R13 (Generic — GCF)
         R13 (AT&T)
         R13 (T-Mobile US)
         R13 (Verizon)
Leaf Workspace Manager
      WP7702 (ATT) Release 13 02.16.06.00
      WP7702 (Generic-GCF) Release 13 02.35.02.00
      WP7702 (Generic-PTCRB) Release 13 02.16.06.00
      WP7702 (Generic-TMOBILE) Release 13 02.13.02.00
      WP7702 (Generic-DT) Release 13 02.22.02.00
      WP7702 (Sierra) Release 13 02.35.02.00
      WP7702 (Verizon) Release 13 02.22.12.00
For details about this firmware release, refer to the WP77xx Release 13 Customer Release Notes.
Generic (GCF)
SWI9X06Y_02.35.02.00 / 001.064_000
002.014
19.11.2
Generic (PTCRB)
SWI9X06Y_02.16.06.00 / 001.028_004
002.014
19.11.2
AT&T
SWI9X06Y_02.16.06.00 / 001.026_001
002.014
19.11.2
Deutsche Telekom
002.014
19.11.2
Sierra Wireless (GCF)
SWI9X06Y_02.35.02.00 / 001.036_001
002.014
19.11.2
T-Mobile US
002.014
19.11.2
Verizon
SWI9X06Y_02.22.12.00 / 001.042_001
002.014
19.11.2
  • WP77xx Firmware Release 13 Components
    This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13 components and how to download it on your product.
WP77xx Firmware Release 13 | Source
