WP77xx Firmware Release 13 Components
  • Aug 6, 2020
  • Version: 13
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13 components and how to download it on your product.
WP77xx Firmware Release 13 combined image
SWI9X06Y_02.35.02.00 / 001.064_001
SWI9X06Y_02.16.06.00 / 001.028_004
Modem Firmware (AT&T)
SWI9X06Y_02.16.06.00 / 001.026_001
Modem Firmware (Sierra Wireless — GCF)
SWI9X06Y_02.35.02.00 / 001.036_001
Modem Firmware (T-Mobile US)
Modem Firmware (Verizon)
SWI9X06Y_02.22.12.00 / 001.042_001
002.014
19.11.2
19.11.2 Source
SWI9X06Y_02.35.02.00 Source
  2. Select the "Target Menu".
WP77xx Firmware Release 13 Components | Source
