(Latest Release) WP7702 Firmware Release 15.2
  • Apr 9, 2026
  • Version: 1
This page describes the procedure to update WP7702 with Firmware Release 15.2.
WP7702 firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 15.2 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP7702 Firmware Release 15.2 Components to create custom firmware packages.
The following methods can be used to install pre-built images on WP7702 modules:
(Windows) 'One-click' tool  1. If not already done, download the latest driver and launch the executable.
 2. Download the Firmware 'one-click' (.exe) file for your carrier:
         R15.2 (Generic)
(Linux) Legato CLI
         R15.2 (Generic)
Leaf Workspace Manager
     WP7702 (Generic) Release 15.2
For details about this firmware release, refer to the WP7702 Release 15.2 Customer Release Notes
Generic
SWI9X06Y_02.36.08.14 / 001.082_000
002.015 SWI9X06Y_03.00.15.03
21.05.4
  • WP7702 Release 15.2 Customer Release Notes
    This is the WP7702 Release 15.2 Customer Release Notes download.
  • (Latest Release) WP7702 Firmware Release 15.2 Components
    This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 15.2 components and how to download it on your product.
