WP76xx Firmware Release 6.2
  • Jan 13, 2018
  • Version: 7
This page describes the procedure to update WP76xx with the Firmware Release 6.2.
This page describes the procedure to update WP76xx with the Firmware Release 7.
         R7 (Generic — GCF)
         R7 (Generic — PTCRB)
         R7 (AT&T)
         R7 (Verizon)
    Legato for WP76 R7 (17.11.0.wp76xx-docker-201801031445) for Windows
    or
    Legato for WP76 R7 (17.11.0.wp76xx-native-x86_64-201801031446) for Linux
      R7 (Generic — GCF)
      R7 (AT&T)
      R7 (Verizon)
Not supported in this release
Consult the WP76xx Release 7 Customer Release Notes
Generic — GCF
SWI9X07Y_02.13.02.00 / 002.018_000
002.006
17.11.0
Generic — PTCRB SWI9X07Y_02.10.01.00 / 002.015_000  002.006 SWI9X07Y_02.13.02.00 17.11.0
AT&T SWI9X07Y_02.10.01.00 / 002.015_000 002.006 SWI9X07Y_02.13.02.00 17.11.0
Verizon SWI9X07Y_02.10.00.00 / 002.014_002 002.006 SWI9X07Y_02.13.02.00 17.11.0
If you build custom Linux Distribution or Base Legato System images for your product, see WP76xx Firmware Release 7 Components to create custom firmware packages.
    Available WP76xx Firmware Releases: WP76xx Firmware Release 17.1 WP76xx Firmware Release 17 WP76xx Firmware Release 16.3 WP76xx Firmware Release 16.1 WP76xx Firmware Release 16.0.1 WP76xx Firmware Release 13.1.1/13.2.1/13.3.1 WP76xx Firmware Release 13.0.1 WP76xx Firmware Release 12.0.1 WP76xx Firmware Release 10.1.1.1 WP76xx Firmware Release 10.1.0.1 &nbsp;&nbsp; Note: If you require access to older releases, contact your Semtech representative.
