WP76xx Firmware Release 13.0.1
  • May 27, 2022
  • Version: 2.0
This page describes the procedure to update WP76xx with Firmware Release 13.0.1
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 13.0.1 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP76xx Firmware Release 13.0.1 Components to create custom firmware packages.
(Windows) 'One-click' tool
         R13.0.1 (Generic — PTCRB) — WP7603, WP7610
         R13.0.1 (Generic — GCF) — WP7603, WP7610
R13.0.1 (AT&T) — WP7603, WP7610
(Linux) Legato CLI
Developer Studio
    Legato for WP76 R13 (19.2.0.wp76xx-docker-201906171318) for Windows
    or
    Legato for WP76 R13 (19.2.0.wp76xx-native-x86_64-201906171319) for Linux
(Linux QMI SDK)
2. Follow instructions from the user guide:
    Linux QMI SDK Application Developer's Guide
For details about this firmware release, refer to the WP76xx Release 13.0.1 Customer Release Notes.
Generic — PTCRB SWI9X07Y_02.28.03.01 / 002.064_003 002.011 SWI9X07Y_02.28.07.02
19.02.0
Generic —GCF SWI9X07Y_02.28.03.01 / 002.064_003 002.011
SWI9X07Y_02.28.07.02 19.02.0
AT&T SWI9X07Y_02.28.03.01 / 002.071_007 002.011 SWI9X07Y_02.28.07.02
19.02.0
  • WP76xx Firmware Release 13.0.1 Components
    This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 13.0.1 components and how to download it on your product.
  • WP76xx Release 13.0.1 Customer Release Notes
    This is the WP76xx Release 13.0.1 Customer Release Notes download.
