WP76xx Firmware Release 10.1.1
- Nov 9, 2018
- Version: 10.1.1
This page describes the procedure to update WP76xx with Firmware Release 10.1.1.
(Note: Links labeled "10.1" indicate items that did not change between Release 10.1 and Release 10.1.1.)
1. Download the USB driver and launch the executable. 2. Download the Firmware .EXE file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R10.1 (Generic — GCF/PTCRB) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610 R10.1 (AT&T) — WP7603 R10.1.1 (Verizon) — WP7601 R10.1 (Sierra Wireless) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610 3. Connect the target's (e.g mangOH) USB cable to your host 4. Launch the executable and follow instructions |
1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R10.1 (Generic — GCF/PTCRB) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610 R10.1 (AT&T) — WP7603 R10.1.1 (Verizon) — WP7601 R10.1 (Sierra Wireless) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610 2. Connect the target's (e.g mangOH) USB cable to your host 3. Open a terminal and execute the Legato command line:
Consult the WP76xx Release 10.1.1 Customer Release Notes
| Carrier Approval |
| Generic — GCF/PTCRB |
SWI9X07Y_02.18.05.00 / 002.041_002 |
002.009 |
SWI9X07Y_02.18.06.00 |
18.06.3 |
| AT&T | SWI9X07Y_02.18.05.00 / 002.040_001 | 002.009 | SWI9X07Y_02.18.06.00 | 18.06.3 |
| Verizon | SWI9X07Y_02.18.05.00 / 002.041_001 | 002.009 | SWI9X07Y_02.18.06.00 | 18.06.3 |
| Sierra Wireless | SWI9X07Y_02.18.05.00 / 001.002_000 | 002.009 | SWI9X07Y_02.18.06.00 | 18.06.3 |
If you build custom Linux Distribution or Base Legato System images for your product, see WP76xx Firmware Release 10.1.1 Components to create custom firmware packages.
