WP76xx Firmware Release 16 Components
- Aug 24, 2020
- Version: 16
WP76xx Firmware Release 16 combined image
| Modem Firmware (Generic — GCF & PTCRB) |
SWI9X07Y_02.37.03.00 / 002.095_000 |
| Modem Firmware (AT&T — PTCRB) |
SWI9X07Y_02.37.00.00 / 002.098_000 |
| Modem Firmware (Sierra Wireless — GCF) |
SWI9X07Y_02.37.03.00 / 001.060_000 |
| Modem Firmware (Sprint — GCF) |
SWI9X07Y_02.37.02.00 / 001.027_000 | Download |
| Modem Firmware (T-Mobile — PTCRB) |
SWI9X07Y_02.35.02.00 / 001.017_000 | Download |
| Modem Firmware (Verizon — GCF) |
SWI9X07Y_02.37.06.00 / 002.107_000 |
002.015 |
SWI9X07Y_02.37.07.00 |
Download R16 |
19.11.2 |
| Legato Source | Release # |
Linux Distro Source | Linux Distro Licences |
| 19.11.2 Source |
R16 | (Based on Kernel 3.18.140 and Yocto 2.5) SWI9X07Y_02.37.07.00 Source |
