WP76xx Firmware Release 16
- Aug 24, 2020
- Version: 16
This page describes the procedure to update WP76xx with Firmware Release 16.
WP76xx firmware is available:
- As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 16 Updates, below.
See WP76xx Firmware Release 16 Components to create custom firmware packages.
1. If not already done, download the latest USB driver and launch the executable. 2. Download the Firmware 'one-click' (.exe) file for your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R16 (Generic — GCF & PTCRB) — WP7601, WP7603, WP7607, WP7610, WP7611 R16 (AT&T — PTCRB) — WP7603, WP7610, WP7611 R16 (Sierra Wireless — GCF) — WP7603, WP7607, WP7610, WP7611 R16 (Sprint — GCF) — WP7611 R16 (T-Mobile — PTCRB) — WP7611 R16 (Verizon — GCF) — WP7601, WP7610, WP7611 3. Connect the target's (e.g mangOH) USB cable to your host 4. Launch the firmware executable (.exe file) and follow the instructions. |
| (Linux QMI SDK) | 1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R16 (Generic — GCF & PTCRB) — WP7601, WP7603, WP7607, WP7610, WP7611 R16 (AT&T — PTCRB) — WP7603, WP7610, WP7611 R16 (Sierra Wireless — GCF) — WP7603, WP7607, WP7610, WP7611 R16 (Sprint — GCF) — WP7611 R16 (T-Mobile — PTCRB) — WP7611 R16 (Verizon — GCF) — WP7601, WP7610, WP7611 2. Follow instructions from the user guide: Linux QMI SDK Application Developer's Guide |
| Leaf Workspace Manager |
For details about this firmware release, refer to the WP76xx Release 16 Customer Release Notes.
| Carrier Approval |
| Generic — GCF & PTCRB |
SWI9X07Y_02.37.03.00 / 002.095_000 | 002.015 |
SWI9X07Y_02.37.07.00 | 19.11.2 |
| AT&T — PTCRB | SWI9X07Y_02.37.00.00 / 002.098_000 | 002.015 | SWI9X07Y_02.37.07.00 | 19.11.2 |
| Sierra Wireless — GCF |
SWI9X07Y_02.37.03.00 / 001.060_000 | 002.015 | SWI9X07Y_02.37.07.00 | 19.11.2 |
| Sprint — GCF | SWI9X07Y_02.37.02.00 / 001.027_000 | 002.015 | SWI9X07Y_02.37.07.00 |
19.11.2 |
| T-Mobile — PTCRB | SWI9X07Y_02.35.02.00 / 001.017_000 | 002.015 | SWI9X07Y_02.37.07.00 | 19.11.2 |
| Verizon — GCF | SWI9X07Y_02.37.06.00 / 002.107_000 | 002.015 | SWI9X07Y_02.37.07.00 | 19.11.2 |
