(Latest Release) WP77xx Firmware Release 15.1 Components
- Apr 27, 2023
- Version: 1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 15.1 components and how to download it on your product.
WP77xx Firmware Release 15.1 combined image
SWI9X06Y_02.36.08.09 / 001.079_000 |
| Modem Firmware (AT&T) |
SWI9X06Y_02.36.06.00 / 001.067_005 |
| Modem Firmware (Sierra Wireless) |
SWI9X06Y_02.36.08.09 / 001.049_000 |
| Modem Firmware (Telstra) |
SWI9X06Y_02.36.08.02 / 001.061_001 |
| Modem Firmware (Verizon) |
SWI9X06Y_02.22.12.00 / 001.042_004 |
002.015 |
SWI9X06Y_03.00.13.00 |
21.05.0 |
Rebuild Linux Distribution and/or Legato from source
| 21.05.0 Source |
SWI9X06Y_03.00.13.00 Source (Based on Kernel 3.18 and Yocto 2.5) |
- WP77xx Firmware Release History item
