WP77xx Firmware Release 14.1 Components
  • Mar 8, 2021
  • Version: 14.1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 14.1 components and how to download it on your product.
WP77xx Firmware Release 14.1 combined image
SWI9X06Y_02.36.06.00 / 001.071_001
Modem Firmware (AT&T)
SWI9X06Y_02.36.06.00 / 001.067_001
SWI9X06Y_02.36.06.00 / 001.043_001
Modem Firmware (T-Mobile US)
Modem Firmware (Verizon)
SWI9X06Y_02.22.12.00 / 001.042_002
002.015
SWI9X06Y_02.36.07.00
19.11.5
19.11.5 Source
SWI9X06Y_02.36.07.00 Source
  2. Select the "Target Menu".
