WP77xx Firmware Release 12
- Oct 1, 2019
- Version: 12
This page describes the procedure to update WP77xx with Firmware Release 12.
WP77xx firmware is available:
- As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 12 Updates, below.
- As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP77xx Firmware Release 12 Components to create custom firmware packages.
| (Windows) 'One-click' tool | 1. If not already done, download the latest USB driver and launch the executable. 2. Download the Firmware 'one-click' (.exe) file for your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R12 (Generic — GCF) R12 (Generic — PTCRB) R12 (AT&T) R12 (Deutsche Telekom) R12 (Sierra Wireless — GCF) R12 (T-Mobile US) R12 (Verizon) 3. Connect the target's (e.g mangOH) USB cable to your host. 4. Launch the firmware executable (.exe file) and follow instructions. |
| (Linux) Legato CLI |
1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R12 (Generic — GCF) R12 (Generic — PTCRB) R12 (AT&T) R12 (Deutsche Telekom) R12 (Sierra Wireless — GCF) R12 (T-Mobile US) R12 (Verizon) 2. Connect the target's (e.g mangOH) USB cable to your host 3. Open a terminal and execute the Legato command line for your preferred installation method:
| Leaf Workspace Manager |
Follow the Leaf Workspace Manager instructions to download and install Leaf and set up your CLI development environment. Important: In the 'Search for a target' step, use the following to search for the latest WP77 packages: leaf search -t wp77xx -t stable -t latest |
1. On AirVantage, monitor the system to be updated. 2. Select More > Install Bundle. 3. Select the desired firmware bundle: WP7702 (ATT) Release 12 02.16.06.00 WP7702 (Generic-GCF) Release 12 02.32.02.00 WP7702 (Generic-PTCRB) Release 12 02.16.06.00 WP7702 (Generic-TMOBILE) Release 12 02.13.02.00 WP7702 (Generic-DT) Release 12 02.22.02.00 WP7702 (Sierra) Release 12 02.32.02.00 WP7702 (Verizon) Release 12 02.22.12.00 4. Start the install procedure. The operation will now be "In progress" state and visible in the System Operations widget. |
For details about this firmware release, refer to the WP77xx Release 12 Customer Release Notes.
| Carrier Approval |
| Generic (GCF) |
SWI9X06Y_02.32.02.00 / 001.055_000 |
002.013 |
SWI9X06Y_02.32.02.00 |
19.07.0 |
| Generic (PTCRB) |
SWI9X06Y_02.16.06.00 / 001.028_004 |
002.013 |
19.07.0 |
| AT&T |
SWI9X06Y_02.16.06.00 / 001.026_001 |
002.013 |
19.07.0 |
| Deutsche Telekom |
002.013 |
19.07.0 |
| Sierra Wireless (GCF) |
SWI9X06Y_02.32.02.00 / 001.027_000 |
002.013 |
19.07.0 |
| T-Mobile US |
002.013 |
19.07.0 |
| Verizon |
SWI9X06Y_02.22.12.00 / 001.042_001 |
002.013 |
19.07.0 |
WP77xx Firmware Release 12 ComponentsThis page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 12 components and how to download it on your product.
