WP76xx Firmware Release 17
- Jun 15, 2023
- Version: 1
This page describes the procedure to update WP76xx with Firmware Release 17
WP76xx Release 17 is a major milestone release with upgrades to Linux Kernel 4.14 and Yocto LTS 3.1. This release also comes with crucial improvements for security vulnerabilities.
WP76xx firmware is available:
- As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 17 Updates, below.
See WP76xx Firmware Release 17 Components to create custom firmware packages.
Important note for the 2-stage AV FOTA firmware upgrade:
- All legacy firmware releases can only be upgraded by AV FOTA to Firmware Release 17 via Firmware 16.3. The AV FOTA process to intermediate Firmware Release 16.3 must firstly be completed before proceeding to the AV FOTA process of upgrading to Firmware Release 17.
- No firmware downgrade back to prior firmware releases is allowed once the firmware is upgraded to Release 17.
1. If not already done, download the latest USB driver and launch the executable. R17 (DOCOMO) — WP7605
3. Connect the target's (e.g mangOH) USB cable to your host |
| MBPL (Linux) |
1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): 2. Follow instructions from the Software Integration and Development Guide for Linux USB Platforms included in the MBPL (Mobile Broadband Package for Linux). |
| Leaf Workspace Manager |
For details about this firmware release, refer to the WP76xx Release 17 Customer Release Notes.
| Carrier Approval |
| Generic — GCF and PTCRB |
SWI9X07Y_02.37.06.05 / 002.128_000 | 002.015 |
SWI9X07Y_03.01.07.00 | 21.05.2 |
| AT&T | SWI9X07Y_02.37.03.05 / 002.130_000 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
| T-Mobile (TMO) | SWI9X07Y_02.35.02.00 / 001.017_001 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
| Verizon | SWI9X07Y_02.37.06.05 / 002.123_000 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
| DOCOMO | SWI9X07Y_02.28.03.05 / 001.024_001 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
| KDDI | SWI9X07Y_02.28.03.05 / 001.026_002 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
| LGU | SWI9X07Y_02.32.03.01 / 001.026_002 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
| SoftBank | SWI9X07Y_02.28.03.05 / 001.028_001 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
| Telstra | SWI9X07Y_02.28.03.05 / 001.058_001 | 002.015 | SWI9X07Y_03.01.07.00 | 21.05.2 |
- WP76xx Firmware Release 17 Components
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 17 components and how to download it on your product.
- WP76xx Release 17 Customer Release Notes
This is the WP76xx Release 17 Customer Release Notes download.
