STT Tool
- Nov 9, 2025
- Version: 1
Serial Trace Tool (stt) is a generic tool for capturing debug traces from a serial trace port. It can be run standalone to capture raw trace data sent from a serial trace port.
Serial Trace Tool (stt) is a generic tool for capturing debug traces from a serial trace port. It can be run standalone to capture raw trace data sent from a serial trace port. A Windows executable is provided for easy use by customers. Source code is also provided for customers wishing to compile and run the tool on other operating systems.
STT ToolTags
HL7900 Standard Debugging GuideThis guide gives high-level instructions for basic debugging of HL7900 modules running Semtech modem firmware.
HL7900 AT Command Reference GuideThis document describes the AT command set used with the HL7900 embedded modules.
HL7900, HL7900E Product Technical SpecificationThis document describes the features and specifications of HL7900 and HL7900E embedded modules and provides you with the information required to integrate them into your products.
