AirPrime - Q2686, Q2687, HL6528x - AT Commands Compatibility Guide
- Oct 15, 2015
- Version: 1.0
This document summarizes the compatibility between AT commands supported by the AirPrime Q2686x and Q2687x with those supported by the AirPrime HL6528x embedded modules.
Since the AirPrime Q26 and HL series use different chipsets and telecom stacks, the real time behavior or response of the modules may vary from one command to another. This document is intended to help the system integrator porting the AT command set between the different modules by identifying differences if any, as well as indicates full or partial compatibility.
AT Commands Interface Guide for Firmware 7.52This document provides full description of AT commands supported by AirPrime wireless modules and AirLink Programmable Gateways.
AirPrime - HL6 and HL8 Series - AT Commands Interface GuideThis document describes the AT command set used with the AirPrime HL6528x and HL85xxx embedded modules.
Location Library for Open AT Framework - AT Command Interface GuideThis document provides Sierra Wireless customers with a full description of the AT Commands for Location Services, available when using compatible GPS receiver in combination with an AirPrime Intelligent Embedded Module.
Security AT Command Interface Guide AT Commands Interface SpecificationThis document provides Sierra Wireless customers with a description of the AT Commands for Security Services over AT commands. This document mainly describes how to configure the security for of an HTTPS connection.
