AirPrime MC73xx FW Package Build 4227
- Dec 3, 2014
- Version: 4227
This package includes approved operator images comprised of FW and PRI. Packages are available for the MC7354, MC7350, MC7330 and MC7304, EM7355, EM7305, EM7330:
- For Windows use the one click updater exe files. This will update both the PRI (carrier provisioning file) and the firmware.
- For Linux use the CWE-NVU packages or the SPK files in conjunction with the ‘Firmware_Download’ application (or equivalent API’s in an application) contained in the Linux SDK SampleApps
(if you do not have access to this please speak to your commercial contact)- The firmware is the .CWE file and the .NVU is the carrier provisioning PRI file.
- The SPK file is an operator approved, combined PRI and firmware file. Generally it is recommended to use this to ensure a unit has an approved combination.
- The packages below are large as they contain all of the specified files (as detailed in the table below) for the specified unit.
Release Components
7355 |
Firmware |
Configuration |
Comments |
Approved |
ATT |
SWI9X15C_05.05.16.00 |
005.008_001 |
Carrier approved |
Generic |
005.007_004 |
PTCRB |
Rogers |
005.005_001 |
Carrier approved |
Sprint |
SWI9X15C_05.05.37.00 |
005.018_004 |
Carrier approved |
Telus |
005.006_001 |
Carrier approved |
Verizon |
SWI9X15C_05.05.16.03 |
005.013_014 |
Carrier approved |
7354 |
Firmware |
Configuration |
Comments |
Approved |
ATT |
SWI9X15C_05.05.16.02 |
005.010_002 |
Carrier approved |
Bell |
005.006_011 |
Carrier approved |
Generic |
005.007_011 |
PTCRB |
Rogers |
005.005_010 |
Carrier approved |
Sprint |
005.018_004 |
Carrier approved |
Telus |
005.006_010 |
Carrier approved |
Verizon |
005.013_014 |
Carrier approved |
7350 |
Firmware |
Configuration |
Approved |
Sprint |
005.018_004 |
Carrier approved |
Verizon |
005.013_014 |
Carrier approved |
7305 |
Firmware |
Configuration |
Approved |
Generic |
005.006_002 |
GCF |
Orange |
SWI9X15C_05.05.47.00 |
005.011_001 |
Carrier approved |
Swisscom |
SWI9X15C_05.05.30.00 |
005.002_002 |
Carrier approved |
Telefonica |
005.006_000 |
Carrier approved |
Telstra |
005.006_000 |
Carrier approved |
Vodafone |
SWI9X15C_05.05.39.02 |
005.010_002 |
Carrier approved |
7304 |
Firmware |
Configuration |
Approved |
Generic |
005.006_020 |
GCF |
Telstra |
SWI9X15C_05.05.26.02 |
005.009_001 |
Carrier approved |
7330 |
Firmware |
Configuration |
Approved |
Docomo |
SWI9X15C_05.05.26.00 |
005.010_000 |
Carrier approved |
AirPrime MC73XX FW Package Build 4227 Release NotesDownload the release notes for MC73xx firmware and PRI package build 4227
AirPrime MC73XX-8805 AT Command ReferenceThis document describes proprietary, password-protected AT commands available for Sierra Wireless AirPrime® MC 9x15-based intelligent embedded modules. These commands are intended for use by OEMs, and are supplemental to the standard AT commands for GSM devices defined by the 3GPP (3rd Generation Partnership Project) in TS 27.007 AT command set for User Equipment (UE) and TS 27.005 Use of Data Terminal Equipment—Data Circuit terminating Equipment (DTE-DCE) interface for Short Message Service (SMS) and Cell Broadcast Service (BSE).
USB drivers Linux DIP Software 3.6_1.7.50Latest USB drivers Linux DIP Software 3.6_1.7.50
Windows Drivers for MC Series Modules (Build 4277)Windows 7/ Windows 8 /Windows 10 Driver Package for MC Series Modules.
AirPrime USB Driver Developer’s GuideThis guide is intended for use when designing non-Windows drivers for Sierra Wireless Modules.
Airprime MC73xx_FW_Build_HistoryThe available FW for MC73xx are : AirPrime MC73xx FW Package Build 4467 AirPrime MC73xx FW Package Build 4399 AirPrime MC73xx FW Package Build 4349 AirPrime MC73xx FW Package Build 4285 AirPrime MC73xx FW Package Build 4227 AirPrime MC73XX FW Package Build 4217 AirPrime MC73xx FW Package Build 4206 AirPrime MC73xx FW Package Build 4151
