What is the Wiring Assembly Layout of the DC Power Cord for the LS300 and GX Series Modems?
  • Jan 13, 2016
This article provides pinouts and diagrams for the DC power cord used with the LS300 and GX Series modems.
The LS300’s and GX Series power have four pins:
  • Two pins connecting DC voltage to the device
  • Two pins providing additional monitoring to the device
Pin 1 – VCC; Connect to +12VDC (red wire)
Pin 2 – Ground; Connect to ground (black wire)
Pin 3 – The ignition sense pin (white wire). The voltage level present on this pin turns the device on and off. NOTE: If you do not connect this pin to the ignition, you MUST connect it to the positive terminal of your power supply/battery.
Pin 4 – Digital input/output (green wire)
LS300
GX Series
What is the Wiring Assembly Layout of the DC Power Cord for the LS300 and GX Series Modems? | Source
