- October 27, 2014
- 1 minute read
- By Sierra Wireless
Snootlab AirPi: 2G/3G + GPS shield for Raspberry Pi
Snootlab, a pure open hardware player, has designed this nice 2G/3G+GPS shield for Raspberry Pi (compatible with A/B/B+ versions). The design of the shield is provided in open source.
The shield is based on Sierra Wireless AirPrime SL8082T module, and can be used either as a bit pipe modem (thru I/Os or USB link) or as a smart modem accepting Open AT applications.
This shield is autonomous and comes with its own power supply and antenna, and powers the Raspberry Pi (then, the Raspberry Pi power supply is not used).
This shield can be used as well as an Open AT SL8082T dev kit when plugged in USB to a PC using the Open AT Application Framework (Developer Studio).
See also
AirPi shield:
- Read Snootlab blog
- Order your AirPi
- Find support for the AirPi on Snootlab forum
Open AT application framework:
- Download Open AT Application framework
- Find support for Open AT on Sierra Wireless forum
AirVantage M2M cloud:
- Eco Tutorial: connect your Raspberry Pi application to AirVantage M2M Cloud using Mihini Eclipse project
- MQTT Open AT sample: connect your Open AT application to AirVantage M2M Cloud using MQTT
- More AirVantage documentation: APIs, libraries, tutorials, code samples
Author
Sierra Wireless
- HW and Embedded SW Developer
- High-level Embedded Solution Developer
- Server-side Solution Developer
